I connect my Bluetooth headphones (jabra elite 75t) to my sense to listen to music via pandora on runs, but recently it's been disconnecting from my headphones mid run. I either have to exit my run tracking to re-connect or continue my run without music (what I usually end up doing).
This only started happening recently after having no issues in the first few months of ownership and is very annoying. I've tried re-pairing my headphones to the watch, but the problem persists. Anyone else had this problem? Any solutions?
Best AnswerHi @Zach_91,
I have a pair of Jabra Elite 65Ts and have never had that issue. I had a brief issue with them yesterday when I tried to listen to music on a walk that had nothing to do with the Sense. I was using them to listen to Amazon Music on my phone and not only did my phone reject the pairing (I had to delete them from the BT Settings), but they weren't syncing to each other. Once I got those issues figured out, they worked flawlessly.
Have you tried re-pairing them to the phone and then re-pairing them to the watch? Also, are the earbuds synced to each other?
one cruise ship at a time!
