I had a blaze for about 6 years and someone gave me the sense for my birthday gift. I was so exited, however I have only gotten for about 6 hrs. I have to un sync it from bluetooth (Clicking on Forget this device), for about 8 times now. Is there a glitch? Does everyone has this problem?
20:20
09:41
05-17-2022
20:20
09:41
Hi, @Andrewsky86 , like the Blaze the Sense must be paired to your phone via the Fitbit app, so you should not need to constantly Forget the device via your phone’s Bluetooth settings. It is likely that the Fitbit will reconnect on its own.
Do you find that you are missing calls or notifications and that is why you are concerned with / checking on your Bluetooth connection? Also, what phone are you using?
Welcome to the forums.
