So it seems that within this past month, something happened with the software or an update from FitBit that has caused my year-old Sense to brick completely. The device has started showing the time (but incorrect), and when I reboot it, it shows NO TRANS and some numbers. If you try to go to Settings, it pops up, nothing there, and goes back to the menu. I did try to pair it, it gives the code but fails. I wish there was a way I could just hook this up to my PC and reflash it...it should not be this difficult.
Hi @adidas374 - your watch probably needs a factory reset, unless it developed a fault, such as water getting in.
You can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support for help with that.
Ok, thanks. I will do it.
