I noticed your watch face doesn't charge if you have your clocks set up in the double Tapp short cut.
But if you swipe to the clocks app through the menu normally it changes.
Anyone else experience that? Hopefully can be fix next software update?
You know the list of four shortcuts that appears if you double-tap the side button? launchermonkey is referring to using a short-cut for the Clock menu there.
I have the same problem, it takes you to the Clock menu correctly but changing the clock doesn't actually do anything.
Best AnswerI don't understand which of the 4 icons I'm seeing would be considered a "monkey"?
Best AnswerWehutty: I have rephrased my post a bit! monkey was a username, but as originally written that wasn’t obvious.
If anyone else has experienced this bug and also found their Fitbit wouldn’t sync afterwards:
Open the Fitbit app on your device.
Visit the clocks selection screen.
You will get a message about continuing to install - choose the option to continue.
Note the clock face that is being processed. (This process never finishes.)
Force quit the Fitbit app.
Go to the clocks screen on your fitbit, using the main menu.
Change to the clock face you noted before.
Reopen the Fitbit app and syncing should work.
