02-01-2022
03:39
09:37
RodrigoMFitbit
02-01-2022
03:39
09:37
RodrigoMFitbit
My new sense watch button is stuck inside the watch. Any thoughts/ advice. Or do I need to bring the watch back. Watch only 1 month old.
Best Answer02-01-2022 05:11
02-01-2022 05:11
The Sense button is meant to be indented. It is not a "button" that pushes in or out; it is touch-sensitive. I suppose being slightly indented is to keep it from being accidentally activated by touch.
02-01-2022 05:35 - edited 02-01-2022 05:36
Welcome to the Fitbit community.
As @JohnnyRow said, that indent is meant to be there and has always been since the day you got it. There isn't an actual physical moving button on the Sense. It's similar to Apple's trackpad or iPhone taptic touch (if you ever used either) where the vibration motor simulates a push.
02-01-2022
05:42
09:33
RodrigoMFitbit
02-01-2022
05:42
09:33
RodrigoMFitbit
Sincere thanks! Every day is a school day! I now realise that Got it sorted.
Thank you so much. All sorted now.
02-01-2022
07:26
09:33
RodrigoMFitbit
02-01-2022
07:26
09:33
RodrigoMFitbit
How did you fix yours? Mine is the same way.
Tara can you help me? Mine is doing the same thing yours did.
JohnnyRow, is there any way you can tell me how to fix mine? I am having the same problem. It will not come on and it will not charge.
Do you know where I can send it back for a refund?
Best Answer02-01-2022 08:09
02-01-2022 08:09
@Janeegurl wrote:JohnnyRow, is there any way you can tell me how to fix mine? I am having the same problem. It will not come on and it will not charge.
As @eezeepee and I noted above, and @Tara9 seemed to acknowledge, thee is nothing to fix. The "button" is touch-sensitive rather than pushing in and out. Please re-read my post above.
02-01-2022 13:54
02-01-2022 13:54
I realised that I needed to change my charger and it then worked for me! The solution is often so simple.
02-02-2022 09:49
02-02-2022 09:49
@eezeepee @JohnnyRow Thanks for your help. Greatly appreciated. @Tara9 Welcome to the forums. I am glad to read everything is sorted out.
@Janeegurl Welcome to the forums. I will gladly help you get your Fitbit Sense running again. Please note that the actuator on the side is not a regular button. This will not physically move. As mentioned above, it is touch sensitive. On the other hand, I recommend you take a look at the following article: Why isn't my Fitbit device charging? - click here. Here you find different tips for this scenario.
Have a nice day!
