04-25-2022
09:36
13:51
EdsonFitbit
04-25-2022
09:36
13:51
EdsonFitbit
I know you can customize which clock face you want. But is there a clock face that allows you to customize what options you want to show? I have a very specific clock face in mind but can't find anything like it. I'd like time, date, calories burned that day, heart rate, maybe SPO2 but that's optional. I prefer all the the metrics to be slightly larger than the secondary metrics are in order to see clearly without my reading glasses. Any suggestions?
17:48
13:15
04-27-2022
17:48
13:15
It's great to see you in the Fitbit Community, @robt541.
Thank you for your question.
Some clock faces allow you to hide or show some stats. It will depend on the app the customization level allowed.
There is a feature suggestion called "Widgets or custom choices on clock faces". You are welcome to vote it and if there is any update, it should be communicated as soon as possible.
Many apps include options to adjust the notifications, allow certain permissions, and customize what it displays. Note that turning off any app permissions might cause the app to stop functioning. For instructions, please visit this article and open the menu "How do I adjust the settings of apps and clock faces on my Fitbit device?".
Have a nice day.
Hi @robt541 - try searching the gallery with variations of criteria like
https://gallery.fitbit.com/search?terms=time,%20date,%20calories%20,%20heart%20rate,%20SPO2
Be sure to check if the clock face is available for your watch.
Also as standard, if you swipe up you can customise what values are shown, may be not as good as a clock face but can be quite large.
