06-23-2021
16:31
13:42
LizzyFitbit
06-23-2021
16:31
13:42
LizzyFitbit
Greeting and Salutations;
I recently purchased the Sense as an upgrade to my Samsung watch. After using if for three weeks my main problem is in the execise part on the sense. It has a lot of things I will never use like Kickboxing, Martial Arts.Pilates, Tennis, and so forth. Is there away to remove these non useful exercises and replace them with things I do? For instance I do cycle so I'll be using that one but in the gym I use the exercise bike which is not on the sense for me as well as the row machine and kayaking. I spend a lot of the time trying to figure out what to use heck I would even like to be to use HITT training cause the interval training part just sucks for me.
06-23-2021 22:44
06-23-2021 22:44
The app does customize itself by no omg the frequently used exercises to the top.
Best Answer03-23-2022 21:05
03-23-2022 21:05
SAME! I just upgraded to the Sense due to the Ionic recall and I remember being able to edit the options shown on my Ionic…
03-23-2022 22:51
03-23-2022 22:51
Hi @krnros - as @Rich_Laue says you don't need to customise the exercises the most recently used get moved to the top, you probably need to sync for it to be remembered.
03-27-2022 11:48
03-27-2022 11:48
I’ve only had it a week or so but have logged 1-2 walks per day and synced several times… any idea how long it takes to remember and move the frequently used to the top?
