05-26-2022 08:08
05-26-2022 08:08
How can I edit the exercise time in Fitbit Sense?
I sometimes forget to stop the tracking after ending treadmill and would like to just cut the time after I stopped.
It would be wonderful if the Fitbit Sense auto-pause if no steps are detected as well. Should not be difficult to implement in the software.
Thanks!
Best Answer05-26-2022 10:12
05-26-2022 10:12
You don't see it because you use Android app which is inferior to iOS version.
05-26-2022 09:36
05-26-2022 09:36
Hello @Dervilo and welcome to the Community. Tap on your exercise tile, then tap on that exercise to got to its Exercise details. There should be three dots in the upper right of the screen. When I tap on that, I get and Edit Exercise Details option. You should be able to fix the time there.
Laurie | Maryland
05-26-2022 09:48
05-26-2022 10:12
05-26-2022 10:12
@Dervilo I am an iPhone user. From time to time, I become aware of differences between the Android and iOS versions of the app. I am very sorry to learn that this is one of the differences.
iOS edit options
Laurie | Maryland
05-26-2022 10:12
05-26-2022 10:12
05-26-2022 12:48
05-26-2022 12:48
Hello @Dervilo
I understand your trying to edit an exercise using your Fitbit App on an Android device. I use an iOS but I did find the information on how to edit/delete an exercise using Android here on the Fitbit help page: https://help.fitbit.com/articles/en_US/Help_article/1306.htm It states you can Edit or delete activities in your exercise history in the Fitbit app. Depending on the exercise, you can choose to edit the type of exercise, start and end times, distance covered, and calories burned. Here’s how: Tap the exercise you want to edit or delete. To delete the exercise, tap the trash icon. To edit the exercise, tap the pencil icon. To edit the type of exercise (for example, to change a walk to a hike), choose a different exercise type and tap Log It.
😃 I hope this helps answer your question
Best Answer05-26-2022 13:14
05-26-2022 13:14
@SunsetRunner this is incorrect. There is no way to edit exercises in the Android app. For some activities it's possible to change type and that's all.
05-26-2022 13:22
05-26-2022 13:22
Thank you for the correction @t.parker 😉 I suppose the Fitbit Help Article should be corrected then.
05-26-2022 13:29
05-26-2022 13:29
@SunsetRunner I read the Help article. It is correct as written.
Laurie | Maryland
Best Answer05-26-2022 13:35
05-26-2022 13:35
@LZeeW the 'edit' part is correct only for iOS users.
05-26-2022 13:38 - edited 05-26-2022 13:42
