08-25-2020 07:26
08-25-2020 07:26
Is the Sense waterproof?
It's not listed on the page that tells you which devices are yet, and it's not mentioned on the product page as far as I can see.
Many thanks.
Best Answer08-25-2020 07:30
08-25-2020 07:30
Hi, yes it's swimproof to 50m so can be used either in a pool or in open water.
08-25-2020 07:30
08-25-2020 07:30
08-25-2020 07:44
08-25-2020 07:44
@Paulioliolio You can find more information here.
Which lists the following information, which @SunsetRunner posted above.
Water Resistant to 50m
Sense is water-resistant to 50 metres, which means you’re free to track laps in the pool and wear it in the shower, at the beach and beyond.
08-25-2020 09:04 - edited 08-25-2020 09:04
Excellent - Thanks Mark
08-25-2020 09:05
08-28-2020 07:53
08-28-2020 07:53
I'm hoping that the new inductive button will help in making the watch water-tight. I had to return one Versa 2 because of water damage, but that was early and my replacement has been rock solid.
06-14-2021 07:01
06-14-2021 07:01
hi do you know if fitbit blaze can be brough in water
Best Answer06-14-2021 07:31
06-14-2021 07:31
I swam and it was fine.
