06-30-2022
12:53
12:24
LizzyFitbit
06-30-2022
12:53
12:24
LizzyFitbit
Is there a way to sync Apple calendar schedule with fitbit?
Best AnswerHello @Uvakmac
Open your Fitbit app, tap your profile picture and then scroll down and tap Sense. Now scroll down to notifications. Make sure calendar is enabled (text and calls if you want them as well) now tap App notifications Find the Calendar app you want in the list and enable it. Make sure you sync your Fitbit Sync if you make any changes so your tracker will accept those changes. Also in order for notifications to work you must enable “Share System Notifications”. If your on a iOS phone go to your Bluetooth and find Fitbit Sense in the list of connected devices. Tap the blue information icon (blue cure with small i inside it) then enable Share System Notifications.
😃 Please let me know if this answered your question. Keep me posted.
