Can't change brightness setting on Sense
I am unable to change the brightness settings on my Sense.  I have done the reset and I still cannot change from dim to normal
3 REPLIES 3
Check if you are accidentally in Sleep Mode.  That intentionally keeps the screen dim.
Just adding on to what @JohnnyRow mentioned, you can check the brightness by swiping right to your "Settings", then selecting "Brightness".  You should see a variety of options to choose from on that list.  Mine is set to "Automatic" so I can see it outside.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
Thanks, you were right. My Sense tracker was on Sleep Mode. After I corrected that the Dim mode automatically went to Normal. Thanks again
