02-12-2023
00:35
09:55
02-12-2023
00:35
09:55
when I go into the notification settings to set up notifications from FB, Instagram, etc., there aren't any apps listed! Help please!
Best Answer02-12-2023 09:57 - edited 07-24-2023 10:13
Hi there, @Rashi07. Welcome to the Community Forums. Thanks for the details provided in your post. @Guy_ Thank you so much for your help.
While reading your post, I was wondering if your Sense is fairly new? If this describes your issue, please note you'll need to receive a message from the app desired in order for your app to show it as option in your Fitbit notification's section. For example, tell someone to send a Instagram message, then check your Fitbit app and you'll see that Instagram is already an option to be selected.
Please note that you can choose 1 app per category. The most common apps for these features are:
However, for "Emails" section you can only select your primary text messaging app (that can be Gmail, your phone's default email app or any other). Nevertheless, in "App Notifications" section you can select more apps, for example if you decided that for your primary Email app you want it to be Gmail, in App Notifications you can enable other email apps.
For more information, see How do I get notifications from my phone on my Fitbit device?
Best Answer02-12-2023 02:34
