06-08-2025
11:31
17:46
EstuardoFitbit
06-08-2025
11:31
17:46
EstuardoFitbit
I was having issues changing my Weather App to be F vs C. The issue with the previous posts was that there is a step that states you should tap your profile pic to navigate deeper in to make this change. Now that Fitbit is part of Google, tapping your Profile takes you to your Google profile. I wanted to post how to avoid this frustrating detail.
In your Fitbit App, at least on an android, tap Today > the Battery percentage in upper left corner > select your Device Picture > Gallery > Weather > Settings > Temperature Unit...choose your unit > select Done...use the back arrows to navigate your way out. Hope this helps!
06-08-2025 17:42
06-08-2025 17:42
Hey @KeikosanBits, welcome to the community!
I'm truly happy to see someone with that willingness to help. Let me add some little detail
06-08-2025 17:42
06-08-2025 17:42
