Hi @Dave89048 - if you don't remember the name or have an email trace for the purchase where the clock face name or developer is mentioned then use search criteria in the Gallery tile to find it.
Sometimes you can do a Google search but then you may get an increas in results to review as clock faces for all watch types will be returned, in the Fitbit App it only shows ones which work on your watch.
Sometimes if your watch doesn't have the latest firmware some clocks or apps might not install.
When you get into the gallery just use the search magnifying glass top right of the page.
You can type in a keyword of some sort to minimize the number of faces that pop up.
From “today” page tap your icon at top left.
Tap the picture of your sense
Tap “Gallery”
Tap “clocks”
