Hi,
I would like to have Bluetooth and Wifi turned off in sleep mode. Is this standard? Where can I see and change this.
The same is for training mode. I run with MP3 player and without smartphone, so I'd like to have the things off I don't need.
Thanks and regards,
Martin
Hi @Martin20202 wifi is only turned on while the Sense is charging. As for bluetooth, it is only listening.
Best AnswerThanks @Rich_Laue . That's good. But can I change those trainings settings. When I go running I e.g. would like to have also a different watch face than during everyday.
Best AnswerYour Sense can store up to 5 watch faces that can easily be chosen from the watch itself.
I'm not sure what ment by "trainings settings"
As for BT the user only has control over the Classic which can be used to control music on the phone or connect to a headphone.
Best AnswerWith the WiFi being only on when charging I am not sure. This morning I wanted to sync watch and phone and it didn't work at all. Then I noticed that my internet connection being down. I restored and everything went fine.
I have to admit I just newly bought the fitbit sense before going for the first training session with it. What I meant is can I change what the sense does in different modes. Obviously when going running he switches on GPS. So there are profiles. Also the watch face changes. Can I configure what is displayed there? Or only swap through the presets? Another example is sleep mode. I change my watch face at night to one which displays Oxygen. I'd like to connect this to sleep mode. Are there this options?
Thanks again.
