12-02-2021 07:53
12-02-2021 07:53
I'm on the latest firmware and the AOD battery icon isn't correct and looks tacky. I've tried restarting the watch multiple times and turning off AOD and turning it back on to no luck.
Thanks
12-02-2021 08:08
12-02-2021 08:08
Hi @Marinor - it's possible to turn it off.
How to configure the status indicator [which was added in the latest version] in the watch Settings, Display.
Best Answer12-02-2021 08:34
12-02-2021 08:34
The status indicators are for low battery, phone out of range, etc. The icon for battery percentage is the one that isnt correct. The battery icon is larger than the progress bar for peecent left.
This was supposedly fixed in the last update, but its still not correct for me.
Best Answer12-03-2021 01:24
12-03-2021 01:24
@Marinor- yes probably not fixed, however you can always use a clock face from the gallery that has a proper battery level displayed instead, and turn on wrist movement and disable the Always On. It generally works well and gives you more battery , so charging less often.
