I almost live by the Main Goal I set. I try to do 250+ steps each hour, and I would like to see that information on a watch face. However, there does not seem to be any watch face that features Main Goal by the hour. Anyone knows of one?
People tastes vary enormously. If you like Analogue, then I use CS1. 4 circles track targets on calories, steps, active minutes and stairs. In addition, there are two configurable areas which you can load with stats and touching them (top and bottom of face) cycles through your choices. eg I have heart rate on top by default and digital time at bottom, but taps cycle me through the other stats. There are quite a no. of data-heavy digital faces though with varying degrees of ugliness.
Hi @JHinOC - Try SimpleClockPro - it always has the steps so far per hour on the main face and also a steps this hour history of all the hours in the day and number of Active hours achieved, along with the ability to change the hours you want to be monitored, along with several reminders per hour.
It doesn't necessarily need to be synchronized with the phone, only to upload information to the Fitbit App. So is virtually autonomous and battery efficient.
