05-14-2021 10:18
05-14-2021 10:18
Is there any way to have the default AoD face with a non-standard watch face? I've found a watch face that I really like, but i don't like the AoD face that comes with it. Can't find a way to set the AoD face without changing the regular face, so thought I'd ask here.
Any way to do this?
Thanks!
Best Answer05-15-2021 05:22
05-15-2021 05:22
Generally there are clock faces, Fitbit and third party from the gallery like the one you like and then there is the watch Always On option which is turned on/off by going to quick settings
Swipe left edge to right and you have 6 options.
The first one [top] controls if AoD is on or not
Quick settings
The middle bottom one is more interesting, as when its on it ensures the watch face you have chosen comes on when you raise your wrist then you don't need the AoD display which drains the battery more.
