When I set a timer on my Sense, and stop it before the time is up. it remains active, in "pause" mode, and I don't see any way to eliminate it.
If I set a new timer, it registers as "Timer 2", but Timer 1 is still sitting there waiting to be reactivated.
How can I remove these zombie timers?
Note the small arrow at bottom of screen; swipe up from there and it gives you option to reset to end.
Note that small arrow is available several places, indicating more options.
There's no small arrow at the bottom of the screen. There's a clock face and the words "add a timer". If I swipe up, I get the option to add another timer, but the first one doesn't go away.
The only way to get rid of it is to let it restart and run out to the end. There really should be a better way. Once this happened late at night, when I had accidentally set a two hour timer. I was about to go to bed so letting it run its course would have woke me up.
I don't see an option to attach a photo, or I would take a photo of the screen.
Best AnswerThe small arrow is there while the timer is running.
