09-18-2021
04:53
07:55
09-18-2021
04:53
07:55
Is anyone having issues with device lock. It should ask for pin no. Once put back on wrist but does not.
Best Answer09-18-2021 07:57
09-18-2021 07:57
Hi there, @Elmo67. Welcome to the Community Forums.
Actually, there are 2 ways you can enable and use the device lock:
Have you check the settings to see which one you've enabled? For more information, see How do I use the device lock on my Fitbit device?
Hope this helps.
Best Answer09-18-2021 08:27
09-18-2021 08:27
Best Answer08-08-2022 10:04
08-08-2022 10:04
I have multiple Sense 3 and Versa 3's and all of them have this exact same issue. Even when device lock is enabled (not just for Fitbit pay) it never asks for the pin when I remove it from my wrist and place it back on. This is clearly a software issue that multiple people are reporting. Does Fitbit intend to fix this issue and if so is there a timeline?
09-04-2022 09:31
09-04-2022 09:31
I have the same problem. It cannot find phone.
