09-04-2022 09:35
09-04-2022 09:35
How can I connect the Sense with phone Bluetooth. The phone simply cannot find the device, even when close to it.
Best Answer09-04-2022 10:34
09-04-2022 10:34
Hello @bothwellm
Try turning your Bluetooth off, wait a few seconds then turn your Bluetooth on again. If that doesn’t work try restarting your Fitbit Sense. You won’t lose any data doing a restart. Just press and hold in the button on your Fitbit Sense until you see the Fitbit Logo then release the button. Try to sync your Fitbit now by opening the Fitbit App and swiping the page downward.
If the issue persist you can try setting up your Fitbit Sense as a new device. You will not lose any data setting it up again as your data is held by the Fitbit servers. You will however lose any data you may have accumulated after your last successful sync.
Here is how you set up your Fitbit Sense as a new device: (please follow the directions closely and do not skip a step)
😃 Hopefully this resolves your syncing issues. Please come back and tell me how it went
