09-19-2022 10:30
09-19-2022 10:30
I've had purchased a new Sense about three weeks ago. I'm having to fiddle and fiddle for 5 to 10 minutes to get the watch to start charging. It drives me nuts. Anyone else having this problem??
Best Answer09-19-2022 12:58
09-19-2022 12:58
Hi @TerriK60 - it's probably a question of cleaning or a faulty charge cable, see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best Answer09-19-2022 22:29
09-19-2022 22:29
The pins on the device or charging cable are dirty. Dust and debris can accumulate over time. Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device? The USB port or outlet is faulty.
Regards,
Will
Best Answer09-20-2022 07:07
09-20-2022 07:07
Only 3 weeks old. Have used 3 different charging cables, extras I have purchased. I have used multiple charging USB ports on several different outlets.
Best Answer09-20-2022 07:12
