04-09-2024 10:42
04-09-2024 10:42
Hi,
As simple as it's read on the title, is it possible to not display all the notification on the watch (for discretion and confidentiality) and keep only the vibration.
And if I want to read it, I just have to push the tactile button.
I do not find such an option in the notification settings.
Thanks in advance !
Best Answer04-09-2024 21:25
04-09-2024 21:25
Hi @Senseo - I have not seen such an option but if you have an Android phone you may be able to delete the notification on the phone before it gets sent to the watch using Macrodroid and instead send a dummy message to cause the watch to vibrate. It can still show the notification (or type if you implement the macro to do it).
See this feature request. Option for vibrate only for notifications (No screen waking)
04-10-2024 02:28
04-10-2024 02:28
Thank you. It's a bit of pity and a surpri5I might say that such a basic feature is natively absent.
Best Answer04-23-2024 16:40
04-23-2024 16:40
My watch vibrates when the display is off. But otherwise not sure if what your asking for is possible otherwise.
