Is there away to disable the temperature sensor on the Sense? Without turning off any other sensors? I'm trying to extend the battery life
Hi @jneumann101 - you can't turn it off and it uses very little battery anyway. Have a look here at the things you can do to improve the battery life, 6 days is achievable on a single charge with the right configuration.
How to resolve the Major issues causing short battery life.
