11-03-2020 06:58
11-03-2020 06:58
When you go for, say a walk, and don't actually touch an "Exercise" type before starting, just let the Sense determine your distance, it is it determined by your phone's GPS, or is it somehow measured by the Sense itself?
Best Answer11-03-2020 07:04
11-03-2020 07:04
Hi @WehuttyWanker.
If you let the Sense auto detect the walk it will be measured using the devices accelerometer. I believe the calculation is number of steps multiplied by stride length (set in your profile).
Best Answer11-03-2020 08:46
11-03-2020 08:46
Thanks, but where, in the settings am I able to set a stride length?
Best Answer11-03-2020 09:57
11-03-2020 09:57
@WehuttyWanker wrote:Thanks, but where, in the settings am I able to set a stride length?
Try this from the app
1. Click your icon on the today screen
2. Scroll down and click Activity and Wellness
3. Click Exercise
4. Scroll down and click Stride Length
If the Set Automatically slider is on, Fitbit will calculate your running stride length based on GPS recorded runs and your walking stride length is based on your height. To manually change either field, you have to turn off Set Automatically, at which point you can change to values in either or both fields to the the stride length you’ve calculated, which will then be used to calculate distance in auto-detected runs and walks. (GPS will still calculate distance if you start the activity from the watch rather then use auto detect.
Scott | Baltimore MD
