01-22-2021 15:55
01-22-2021 15:55
Has anyone gotten Assistant to work? I've installed it on my Sense but it doesn't seem to "hear" me when I speak. Any ideas?
Best Answer01-22-2021 15:59
01-22-2021 15:59
It does if your microphone is working. Mine worked up until a week ago. Now it doesn't register that I'm even talking.
Best Answer01-22-2021 17:18
01-22-2021 17:18
Thx! The microphone is probably the problem.
Best Answer01-22-2021 20:19
01-22-2021 20:19
Did you try
On the watch Swipe left Click settings Vibration & Audio Scroll to Microphone Make sure its on |
Best Answer01-22-2021 20:40
01-22-2021 20:40
Yes, its been on.
Best Answer01-22-2021 21:29
01-22-2021 21:29
How are you starting Google Assistant?
Best Answer01-22-2021 23:34
01-22-2021 23:34
I open the Fitbit app on my phone then open Assistant app on Sense. I see "Hi, how can I help?". It doesn't respond to my voice and then next screen is "Try saying things like..."
02:20
06:59
01-23-2021
02:20
06:59
It seems like your microphone not working is a general problem, affecting quite a few people.
Probably best to inform Fitbit Support directly. They may be able to help you.
Best Answer01-23-2021 02:48
01-23-2021 02:48
Thanks for the tip. You're right, Support is the way to go.
Best Answer01-23-2021 12:30 - edited 01-23-2021 12:32
When using Google assistant on the wrist, everything is done from the wrist.
First I'll assume you have, through the Fitbit app, setup Google Assistant.
Now on the Sense.
Hold in the button.
A message pops up.
Start talking and release the button. As you talk you should see a wavy line on the sense.
Failure to release the button soon enough will restart the tracker.
Your phone only needs to be close enough for a Bluetooth connection.
Best Answer01-23-2021 12:33
01-23-2021 12:33
Can you answer phone calls from the wrist? Or respond to text with voice?
Best Answer01-23-2021 13:38
01-23-2021 13:38
I spent a while with support and they couldn't fix it. I'm waiting to hear from someone else.
Best Answer01-23-2021 22:03
