09-25-2020
11:23
16:45
LizzyFitbit
09-25-2020
11:23
16:45
LizzyFitbit
Hay I've received my Fitbit sence today 🙂
But the bad bits my phone not snycing with watch. Can't receive notifications on watch just keep saying restart phone ( which done lots of times ) and can't add the pay ...keeps saying bank not accepted. So all in all not a good start !!!! Help !
Best Answer09-25-2020 11:44
09-25-2020 11:44
I had the notification issue with my versa on my P30. I found changing the setting in my phone in 'battery' and then manage how apps launch, changed fitbit to manage manually and its been fine since and my new sense is working great with the p30.
09-25-2020 16:56
09-25-2020 16:56
Hi @Wakefield53 and @Frans22. Welcome! It's good to see you here in the Community.
@Wakefield53, I'm glad that you got your Sense and thanks for sharing the issues that you've had with it. Does the message to restart your phone appear when trying to sync? Have you made sure to have the Fitbit app updated? Please give a try to the suggestion posted above and check this help article for more troubleshooting steps to get your watch syncing correctly. Once that is done, you can go ahead and set up your notifications and the Fitbit Pay. I'll look forward to your response.
@Frans22, thanks for sharing the steps that worked for you. Your post is very helpful and I'm sure will help other members experiencing similar issues. Hope you enjoy the experience with your Sense! 😎
I'll be around if you need anything else.
Best Answer10-25-2020 04:29
10-25-2020 04:29
Hello,
I have the same issue. got my sense 2 weeks ago and it syncs for 1 day and then I have to reinstall because it stops working. it's very annoying and I don't want to keep the watch if it continues... I would not recommend the watch anymore. either you fix it with some kind of update or you take it back. a watch in that price segment should just work...
Best Answer10-25-2020 16:57
10-25-2020 16:57
I have a p30 as well and sometimes it doesn't always sync. I have to re-start my phone and then sync with the app,and that works. Hope this helps.
Best Answer10-26-2020 03:09
10-26-2020 03:09
Hi, I want to get a either a working new sense or to be refunded... the syncing issue makes the watch unusable for me.. could you please give an advice how to send the watch back??
I tried all the troubleshooting advices here...
best regards,
M.
Best Answer10-26-2020 21:20
10-26-2020 21:20
Same here!! -> Can't receive notifications on watch just keep saying restart phone ( which done lots of times )
Best Answer11-01-2020 11:44
11-01-2020 11:44
Hi @mitchibiena and @xnonsense. Welcome to the Community Forums. @SunsetRunner, it's good to see you around.
Thanks for letting me know that you're having syncing issues with your Sense, as well for the steps tried prior to posting. I'm sorry for this inconvenience and I'll help you with this situation. Because you have Android phones, please give one last try to the following:
@mitchibiena, about your other inquiry, we provide refunds to any order purchased from our Fitbit store that is within 45 days as described here. If you got your watch from our store, please let me know so I can get you in touch with our Support team.
@xnonsense, while your Sense isn't able to receive notifications, may I know if it's able to sync correctly? If that's correct, I'd suggest to try the troubleshooting tips from this help article.
Best Answer01-19-2021 11:11
01-19-2021 11:11
Hi all, I have a question for those unfortunate buyers who are experiencing synchronisation issues with their Fitbit and Huawei P30 phone:
Did you encounter the connecting/syncing issues from the very first day onwards or did these only appear after a while? If you could confirm you had it from the start, I’m considering a purchase since I’d be able to determine whether it will work for me within the 45day free return period.
Kind regards,
Len
Best Answer01-23-2021 16:56
01-23-2021 16:56
Hi @Len_de_Mooij. Welcome to the Community Forums.
Thanks for your interest in the Fitbit Sense. Let me clarify that your Huawei P30 phone is a compatible device, meaning that the Fitbit app has been optimized to work on your phone. I understand your concern and to make sure every feature will work flawlessly I'd recommend to verify the requirements described for each feature in either our help site or the User Manual.
Have a good day.
