01-10-2021
06:24
06:35
WilsonFitbit
01-10-2021
06:24
06:35
WilsonFitbit
My EKG results stopped syncing from the sense to the Fitbit app. All other data is still properly syncing. I’ve already done trouble shooting by turning off and on the Bluetooth and also turning off and on both the Sense and the iPhone
01-11-2021
06:35
08:44
01-11-2021
06:35
08:44
Hello @Timr13 Welcome to the Community Forums! Thank you for the troubleshooting steps you've tried prior to posting.
If you take more than 5 ECG readings before syncing, they won't appear in the Fitbit App. I would suggest you to sync your Sense to save the readings. For more information, please check: What is the Fitbit ECG app?
If this continues, please confirm if you followed all the tips suggested here and confirm the model of your mobile device and its operating system.
I look forward to hearing from you.
01-11-2021 08:01
01-11-2021 08:01
01-11-2021 12:02
01-11-2021 12:02
I have the same issue, and tech support says its an Apple issue.... Not sure what is happening
01-13-2021
09:32
08:44
01-13-2021
09:32
08:44
@Timr13 It's good to se you around! @JennLovesTravel Welcome to the Community Forums!
@JennLovesTravel I was informed by the Support Team that you have contacted them and they have provided assistance. If you have questions about the outcome of your case, I recommend replying back to the email they sent to you.
@Timr13 I would suggest that you please confirm that your Sense is connected to Wi-Fi, then please force quit the Fitbit App and manually sync your Sense. For manually sync, please check: How do Fitbit devices sync their data?
On a side note, please take into consideration that ECG results don’t appear immediately. It takes at least 10 seconds (and up to 10 minutes) to see the ECG results in the Fitbit app.
01-14-2021 13:17
01-14-2021 13:17
Wilson - thanks for the reply. I have responded to their email and have done everything they recommended. Once sensed all other activity, including the EDA scan sync’s, except the ECG. The last EDA sync was 12/24/20
01-15-2021 03:37
01-15-2021 03:37
@Timr13 If you have contacted Customer Support, I recommend updating your case with the information you provided so they can continue assisting and follow up your case.
Have a great day!
02-24-2021 04:17
02-24-2021 04:17
I'm having the same issue. I have a pixel 3 XL (android), and my Sense ECG synced 2 times in February but no results show up since.Everything else syncs fine. Did this get resolved? Is there a solution?
02-28-2021 21:08
02-28-2021 21:08
I had the same issue with my ECG reports not syncing to the app for the last 2 weeks. I did a shutdown of the device and that didn't help. Gave up for a couple of days and then today did a force stop of the app through settings. At first it didn't look like it helped but I checked for the recent ECG reports that were missing and they showed up!
07-09-2022 22:27
07-09-2022 22:27
I've recently been having the same trouble: ECGs taken don't show up in the Fitbit app after syncing. I found that a restart of the watch had no effect on the problem, but doing a force-stop on the Fitbit app on my phone (Android v3.62, version was updated on Jun 24, 2002), caused some of the ECGs to show up after restarting the Fitbit app and manually selecting the watch to sync.
This was particularly troubling, because I'm an Afib patient, recently had an ablation, and I've been trying to diagnose a potentially serious arrythmia. Not being able to display the 30 second ECGs that I take is a serious, serious, SERIOUS, major malfunction, repeat, a MAJOR MALFUNCTION, in Fitbit software. It's particularly disturbing that there is no indicated error message in the Fitbit app, it just fails to upload the ECG data.
The ECGs that I'm getting look rather strange, with a trace that looks like half-dome in side view showing up as often as every 4 beats. The ECG software is so bat**ahem** complicated that I thought it was some strange electrical problem with the Sense watch, but it seems not. Its really frustrating that the unreliability of the ECG software has been delaying my understanding of this serious health issue.
