Hello all,
I bought my sense few weeks ago in Canada and now that i'm back in Italy for holidays i'm able to test the ECG app.
Is it normal that i have like 15/20 bpm difference when i compare an ECG reading and the one from optical sensor?
Or should i get in contact with the Customer service?
Best AnswerI tried this morning after i woke up and was not able to do it because for the ECG i had always a rate lower than 50bpm(40/45) while on the watch/fitbit app the optical sensor was showing around 60.
I tried like 6-7 times and always the same situation.
I tried later during the day and, while i'm able to take ecg, the difference between the 2 sensor is always there.
What i do is:
-check the heart rate on the watch for few seconds to be sure that is updated and that there are no big changes(last one i was between 78-80)
-ECG for 30 secs
-after finish the ECG, check again the rate shown on the watch for few seconds(again, the last time i was same as the beginning so between 78-81)
-check ECG report and using the average bpm(last one was 60) to compare it with what i had before and after with the optical sensor.
Attaching the report if it can be of any help.
Best AnswerI checked again, 30 minutes after a workout and everything was fine.
Optical was between 88-90 with a short drop to 82 before i started the ECG and after the ECG it was again between 87-90 while the average bpm from ECG was 86.
Will try again tomorrow to see if i'll get anything strange.
