05-04-2023
22:44
07:07
05-04-2023
22:44
07:07
Exercise app on my Fitbit Sense has stopped working? When I select it just goes straight back to main screen? Also noticed today the settings app had disappeared & had to reinstall that? Have restarted watch twice but still not working.
This happened to me last month. I had to Uninstall my fit bit app and reinstall it, which didn't make sense but it worked
Ditto also still not working
Best AnswerI have just uninstalled & reinstalled the Fitbit app but has not fixed the problem.
Best AnswerSame!! so frustrating! The first reason I have stuck with Fitbit is unity and challenges, and they took that away. - which I think was very intentional. Then the exercise app no longer works which was my second reason for utilizing Fitbit😡
Best AnswerA full factory reset seems to have fixed the problem? 👍
Re-open the Fitness App
It's not always healthy for your device battery to close the recent apps every time. However, when such a problem arises, or when your app crashes or is not working, you should close the apps and re-open them
Regards,
Diana
