08-07-2023 04:21
08-07-2023 04:21
The exercise shortcuts listing is missing from the menu in my app. Subsequently I cannot record an exercise using my sense. I have done a reset on my sense and I have also deleted and reloaded my app but it has not fixed the problem
Best Answer08-08-2023 15:56
08-08-2023 15:56
Hi @ErinDM. There is no exercise shortcuts list for the Sense. All the exercises available are already preprogrammed onto the device.
You can create a double tap shortcut of four exercises on your Sense by going into Settings > Shortcuts > Double Press.
As far as exercises not recording, have you tried doing a total factory reset? Can you explain the behavior you’re experiencing when you try to start an exercise?
Best Answer08-08-2023 22:01
08-08-2023 22:01
