08-07-2022 08:57
08-07-2022 08:57
Update got stuck at "Searching For WIFI Connection"
Realized that the WIFI connection within the Fitbit app needed to be updated since getting a new router recently. Problem solved. Hope this helps someone having the same problem.
08-07-2022 10:22
08-07-2022 10:22
Thanks for the reminder. I just switched wifis as well.
08-08-2022 06:50
08-08-2022 06:50
What does the update change?
Best Answer08-08-2022 17:54
08-08-2022 17:54
See this link: https://help.fitbit.com/articles/en_US/Help_article/2302.htm#
There are no details on "bug fixes and improvements"
Best Answer08-09-2022 04:42
08-09-2022 04:42
I have reset my wifi connections and verified connectivity, and the Sense still will not go through the firmware update. Keeps getting stuck and giving me a big red X. I turned the blutooth off and on, rebooted the phone. I finally gave up on it this morning and will wait to see if anyone has suggestions.
09-10-2022 18:42
09-10-2022 18:42
Thanks for posting. I had the same issue and this resolved the problem
