10-22-2020 01:34
10-22-2020 01:34
Hi!
Yesterday after I did my i ital setup with a slooooow long firmware update I got things started. My phone app then said there was a firmware update and if I wanted to run that. As I needed to leave the house I didn't run it right then and it disappeared. I figured it might only show up while on the charger, but it never came back.
My skin temperature check actually says I need to update my firmware to be able to use that.
Does anyone have an idea how to proceed???
I'm on firmware 44.128.1.42
Help??!!
10-22-2020 12:08
10-22-2020 12:08
Hi @Valalilly you already have the latest firmware on your Sense, be aware though that the watch needs a few days before it starts to show the skin temperature data. You will also find that the update message will also disappear.
10-22-2020 02:03
10-22-2020 02:03
从启动或者删除设备,从新绑定即可
Best Answer10-22-2020 05:09
10-22-2020 05:09
What is a "new binding"?
Best Answer10-22-2020 06:30
10-22-2020 06:30
Re-add after deleting device
Best Answer10-22-2020 12:08
10-22-2020 12:08
10-22-2020 16:53
10-22-2020 16:53
I'm on firmware 44.128.1.42, same as you, and I do have skin temperature, you probably just need to wear it to sleep for at least 3 night, but sometime it will take longer than that, mine took about 10-12 night before it came on.
10-23-2020 00:12
10-23-2020 00:12
Thanks everyone, I'll just be patient then and wait with more drastic measures 🙂
