10-03-2020 03:27
10-03-2020 03:27
I'm having the same issue but with the mindfulness tab.
I have restarted the app logged out and logs in and restarted my phone. This happened after I did a guided EDA Session. It was working fine before. I can't access the mindfulness sessions now as a result.
10-03-2020 07:54
10-03-2020 07:54
Exactly the same issue. Worked before the first guided session, now force closes every time. Shows a couple of SQLite Errors in the Android dump, one indicating that a child entry was written to DB without a corresponding parent entry.
10-08-2020 19:49
10-08-2020 19:49
Same issue here, any resolution?
Best Answer10-08-2020 20:02
10-08-2020 20:02
I Uninstaller and reinstalled the app and the issue is fixed
Best Answer10-10-2020 01:37
10-10-2020 01:37
For now, the only thing you can do is uninstall and reinstall the app. But any time you select a guided mindfulness session the issues will return.
Best Answer10-10-2020 01:38
10-10-2020 01:38
The issue is fixed temporarily but when you use the guided session again it crashes.
Best Answer10-10-2020 05:20
10-10-2020 05:20
Could be the amount of new users crashing that party of the app also. I was having the same issue and I cleaned the cache and datafrom the app and it started working
Best Answer10-28-2020 05:01
10-28-2020 05:01
Same issue and the only fix was uninstalling app and reinstalling app. I've had to so this 3 times in the last month or so since I got my new fitbit Sense. Hopefully fitbit fixes soon. Extremely annoying especially when paying for premium.
12-04-2020 11:30 - edited 12-04-2020 11:37
I contacted Customer Service and I seemed to know more about what was going on then they did. Couldn't provide any feedback and closed my ticket with no solution.
