I love the sense and all it’s options but I’m having a problem with the battery. After a day or two the battery drains and I have to recharge. I had the Versa and the battery lasted at least 5-6 days with notifications and all.
Is this just the way it is? Should I return it? It supposed to last at least 5 days
Hi @fleyton - first check which features you are using, as Snore detection and SpO2 can use as much as 4 days battery, see the full list How to resolve the Major issues causing short battery life.
