02-25-2021 05:50
02-25-2021 05:50
My Sense detects incoming calls and texts but i cant make it vibrate
Best Answer02-25-2021 06:20
02-25-2021 06:20
Hello @William35! Have you checked the device settings for vibrations? Swipe left until you see the "Settings" icon. The second option should be "vibration & audio". You can choose between light or strong, I would choose strong. If that doesn't work, I would explore your phone's settings in depth.
02-25-2021 10:17 - edited 02-25-2021 10:18
Swipe from left to right and Disable Sleep and DND modes.
02-25-2021 11:47
02-25-2021 11:47
Thanks
have disabled sleep - and DND thanks
Will try
Best Answer02-25-2021 11:48
02-25-2021 11:48
Thanks Heather
Tried all that to no effect
Grateful for your assistance
17:33
10:49
02-28-2021
17:33
10:49
Hi @William35, welcome to the Community Forums. @Heather-S and @Rich_Laue, thanks for your amazing help!
@William35, thanks for trying the steps suggested above. Even though your Sense doesn't vibrate when receiving notifications, is it able to vibrate for silent alarms, reminders to move or when pressing the button? If not, I'd recommend you to restart your watch as this will refresh its performance and monitor its behavior in the next days.
