02-14-2021
09:16
11:42
ManuFitbit
02-14-2021
09:16
11:42
ManuFitbit
Would like to return my Fit Bit Sense because it is defective already after 45 days of use. I hold the button down on the side and it will not restart. The logo flashes on the screen, and disappears. It does this constantly even if I am not pressing the button.
Moderator edit: clarified subject.
Seems like this is a serious issue.
Probably best to inform Fitbit Support directly. They may be able to help you replace it or over the counter..
