Hi, @Ikky29, welcome to the community, in short, the answer is YES. Settings and screen displays can be adjusted as you desire. Swipe left from the clock face>exercise>swim> you will see a little chevron at the bottom of the screen, swipe up>set pool length and other stuff, "Show Stats" allows you to self define the screen, The middle stat is the biggest, I have this set to lengths, my eyesight is not very good so I ignore the others but of course, you can set it up as you wish. Once set up swipe down back to the "Start" arrow, touch the arrow to get screen lock and commencement of the swim. While you are swimming you can flick your wrist to see the stats or you may have decided to have the display on constantly (not really necessary in MHO) Once you have completed your swim touch the side sensors twice to get the "Finish" flag, touch it to end your swim. The next time you are within range of your phone the app will update with all the stats.
I hope this helps.
Cheers
Gr4ndp4 | UK
I hope this helps.
Cheers
Gr4ndp4 | UK
Thank you very much for this info @Gr4ndp4 . Just to reconfirm before I make the purchase decision....you are saying the FITBIT Sense does show the laps while I'm swimming...... repeating this again because I saw a lot of other users on this community complaining that the Fitbit Sense and Versa3 DO NOT show activity details while in the swimming pool.
Please reconfirm. Much obliged for your help 🤝
I use my Fitbit "Sense" daily as described.
Cheers
Gr4ndp4 | UK
