03-24-2021 04:42 - last edited on 03-25-2021 18:58 by LiliyaFitbit
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
I have had my Sense for two months. I have never got HRV reading after an EDA scan. I have tried to wear the device in various places on my wrist. I am keeping still. My palm is in contact with the metal frame. No matter what I try to do, I always get "unable to detect".
03-25-2021 18:57
03-25-2021 18:57
It’s good to see you in the community, @LokeAa.
Thanks for the details shared in your post and for already trying to resolve the issue. I recommend doing the following:
1. Check if your Fitbit app is updated to the latest version: How do I update the Fitbit app?
2. Sync the app.
3. Restart your watch: How do I restart my Fitbit device?
4. Restart your mobile device.
You can confirm the instructions at How do I start an EDA scan on my Fitbit device?
Hope this helps!
03-25-2021 18:57
03-25-2021 18:57
2. Sync the app.
Hope this helps!
03-01-2022 10:50
03-01-2022 10:50
It's kind of laughable that something that should work basically but you have to go all through these loopholes to get it to work.
It's like back in the day when you had to blow into a Nintendo system to get the dust out.
Best Answer03-01-2022 10:51
03-01-2022 10:51
And the other thing is how does it measure your heart rate variability when you're sleeping and your hand is not even being pressed against the Watch?
Best Answer08-30-2022 11:21
08-30-2022 11:21
Having the same issue. Can never get it to work. Likely getting an Apple Watch next time I decide to get another smartwatch.
Best Answer08-30-2022 11:23
08-30-2022 11:23
This doesn't fix the issue. If it did, it would only be intermittent. I shouldn't have to reset my watch each time I want to do an EDA scan.
