Fitbit Sense unlock swimming lock
Using my Fitbit Sense in Swimming mode, once out of the water I was unable to unlock it , it subsequently drained the battery. I have recharged it ( I think) checking the connection is correct each time but still no response at all.
I hope you can help as this has been a most useful watch and didn’t know how much I refer to it now it is not working. Many thanks.
4 REPLIES 4
Hi, @705MAN a rapid double touch of the side button usually does the trick for me. It sometimes takes two or three tries and I find it helps to dry off the watch face. Not helped either by lack of spectacles and a trembling hand following the effort put in while swimming.
I hope this helps.
Cheers
Gr4ndp4 | UK
Thanks for the feedback it’s really appreciated I’ve dried out the phone, my fingers etc, and numerous attempts at a double tap but still a lifeless Sense !!!! 24 hours later it’s still the same.
Regards David
Sent from my iPhone
Hi, @705MAN , I suggest you talk to "Customer Support" here
I recommend using the chat facility or phone for a prompt response.
Cheers
Gr4ndp4 | UK
Brilliant, thank you
