01-24-2021
14:37
07:49
WilsonFitbit
01-24-2021
14:37
07:49
WilsonFitbit
The voice replies on my sense for texts won't work. I've tried restarting my watch, phone, the app, deleting the cache...all of it and still won't go through. Should I just return for something else?
Moderator edit: word choice
Best Answer01-25-2021 07:46
01-25-2021 07:46
Hello @Dhomyn Welcome to the Community Forums! Thank you for the troubleshooting steps that you've followed prior to posting!
I would recommend performing an update to the Fitbit App. For this, please make sure to follow the correct steps from this help article:
In addition, note that your phone must be nearby with Bluetooth turned on and the Fitbit app running in the background. To use the microphone in Sense, in the Settings app, make sure the Microphone setting is turned on.
If the issue persists, please proceed with the following:
1. Tell your phone to "forget" the bluetooth connection to your Fitbit device:
2. On your phone, tap Settings > Bluetooth.
3. Tap the information icon or gear icon next to the name of your Fitbit device.
4. Find the option to forget the device.
Then, please setup the notifications and quick replies again. For more information, please check:
How do I get notifications from my phone on my Fitbit device?
Let me know how it goes.
Best Answer02-23-2021 09:10
02-23-2021 09:10
How do you ensure the Fitbit app is running in the background? I think this is the issue in that half the time I need to use the voice dictation to a message, I haven't opened the app in the last few hours.
Best Answer02-24-2021 08:48
02-24-2021 08:48
Hello @KDDC, it's great to see you around!
Best Answer02-24-2021 08:59
02-24-2021 08:59
Thanks for that. I checked and there is 1 process and 1 service running. Fitbit Notification Service and Fitbit Process.
It still doesn't work. Any other suggestions?
