03-10-2022 07:56 - edited 03-10-2022 07:59
Weather says Fahrenheit but displays celscius temperature and it won’t change.
03-10-2022 08:06
03-10-2022 08:06
@Bsongbyrd Hello! Have you tried restarting your Sense or the Fitbit app on your phone?
Best Answer03-10-2022 08:30
03-10-2022 08:30
Hi @Bsongbyrd - here is how to fix it How to change Temperature - for Weather, Centigrade - Fahrenheit, Sense
Best Answer11-03-2022 10:16
11-03-2022 10:16
If you still can not configure the watch to show the Fahrenheit, you can try the alternative method below.
01-03-2023 12:42
01-03-2023 12:42
This doesn't fix my issue. I am so frustrated with it.
01-03-2023
20:50
10:30
01-03-2023
20:50
10:30
Hi @lauraresnick - did you follow all the steps in the link I posted earlier which covers the various places to change units?
Also if you have a syncing problem any changes you make in the Fitbit App won't appear in the watch. In which case try logout of the Fitbit App and restart the phone and watch.
Best Answer01-04-2023 05:24 - edited 01-04-2023 05:24
I have done that. I am trying a dif weather app today. If not, I'll just learn celsius . Thanks very much though
01-04-2023 08:24 - edited 01-04-2023 08:30
Same issue here.
I've tried resetting the temp to C then back to F. It still say the wrong temperature. How can such a core feature simply be broken and ignored?
Fixed it.
Fitbit app -> click on your device -> gallery -> (opens app store thing) -> search for weather -> click on the fitbit weather app -> settings -> set to Farenheight.
Dumb that it ignores the system setting, but it's working for me now.
01-04-2023 16:34
01-04-2023 16:34
Was having same problem. Thanks for the fix
Best Answer03-08-2023 10:10
03-08-2023 10:10
Thank you so much for the fix. This has been driving me crazy for months.
03-20-2023 11:04
05-05-2023 05:11
05-05-2023 05:11
I keep having the same issue!!! Frustrating as heck!
Best Answer05-05-2023 05:25
05-05-2023 05:25
Hi @Kris1111 - here is how to fix it How to change Temperature - for Weather, Centigrade - Fahrenheit, Sense
