07-31-2021
14:48
12:34
WilsonFitbit
07-31-2021
14:48
12:34
WilsonFitbit
My fitbit sense seems to be dead it won't charge I have tried everything recommended brushing the connections with a toothbrush but nothing seems to work would anyone know what else I could try
Best Answer08-01-2021 06:01
08-01-2021 06:01
Its a common problem, the charger attachments can often show a defect, check the 4 pins are equally prominent.
If not, get a replacement charger under warranty.
You can contact Fitbit Support directly. They should be able to send you one.
08-01-2021 06:01
08-01-2021 06:01
08-17-2021 17:57
08-17-2021 17:57
Having the same issue! Guess I will try a new charger!
