11-04-2021
13:35
14:27
LizzyFitbit
11-04-2021
13:35
14:27
LizzyFitbit
Fitbit Sense won't charge or start. It's still under warranty. Please help.
Thanks.
14:05
06:04
11-04-2021
14:05
06:04
Hi, if it won't charge the battery will be flat and it can't be started.
Check the 4 pins on the charger, to see if they are equally prominent and well located. It is often a cause of not charging.
If it's faulty get a replacement charge cable under warranty.
In addition to what @Guy_ mentioned, you could also contact Support and ask for a Battery Test. If there's a charging issue, there's something wrong with either the battery or cable, and the Battery Test can tell us which one it is.
one cruise ship at a time!
