I think this must be a bug in the app for so many people to have this happen today. I was advised to factory restart, but I may have received these instructions with the understanding that my Fitbit is two days old, and there's nothing to resetting it.
I've seen some good advice on this forum. Good luck.
Hello @alekhgpt @NarcanWitch @Mimi_C_123. Welcome to the community forums! @NarcanWitch Thanks for your great input!
If you experience any syncing inconvenience, I'd suggest trying to perform the troubleshooting steps suggested in this help article:
Why won't my Fitbit device sync?
Also, take into consideration that the Fitbit App works well with any device that meets the requirements listed in this link.
Hope this helps.
