03-24-2021 18:57
03-24-2021 18:57
My fitbit sense suddenly black screen and not able to turn on although i try the tips on the forums.Where can i get the repair at malaysia?
Best Answer03-25-2021 01:37
03-25-2021 01:37
If you have tried charging [and syncing while charging to see if its on] - it may come on by itself.
Have a look at the suggestion posted here to check it is actually charging
Also try to use the button without using your nails when its charged.
Worn on the left arm -
rest your other thumb on the arm to the left of the watch and forefinger on the back of the hand and do a gentle squeeze of the watch |
Fitbit watches aren't repairable - As its under warranty probably best to contact Fitbit Support directly. They may be able to help you.
Best Answer03-25-2021 01:49
03-25-2021 01:49
Hi guy,
Thanks for the tips given.
Unfortunately it cannot turn on although i try all the method you mentioned.
Already contact fitbit support and they will send one replacement since it still under warranty.
