Hi KYU, I've loaded your "Simple (Weather, Seconds, YMD)" clock face and love it so far.
The only issue I'd like to have the temperature display in Fahrenheit, not Celsius. I've changed all places that I can find in the Fitbit app that references temperature unit to F, but the clock face is still showing C.
Hope you get this and can help. Thanks.
Hi @Jeresh - check in the Fitbit App where you installed the clock face for a temperature setting, if there isn't one, try adjusting the weather app temperature units settings and sync.
Hold the button for 10 seconds till it vibrates and the logo appears and wait for it to start to ensure changes take affect.
Failing that contact the developer directly where you installed the clock face at the bottom.
