02-25-2022 23:56
02-25-2022 23:56
I did a 10 miles run last night the distance has been calculated correctly but the map not, it’s missed half the map off, it’s converted to Strava the same so must be a Fitbit issue! Any advice or is it just GPS?
I was in town for the parts missed off so it should be ok
Best Answer02-26-2022 12:57
02-26-2022 12:57
Yes, it appears that the GPS lost signal and probably was never able to reconnect again. The reason the distance is correct is because your Sense used your steps to be estimate the distance.
