06-29-2021
16:44
09:46
LizzyFitbit
06-29-2021
16:44
09:46
LizzyFitbit
I have seen this several times. On board GPS and exercise tracking works well, as long as you never touch your iPhone. However, if you touch your iPhone for any purpose (call, text, check weather), the GPS and exercise tracking shut down and do not restart, even if you stop using the phone. It’s the only reason I coughed up $300 for the Sense. The Sense is non-Sense. My Verse worked better. It relied on the phone for GPS, but didn’t stop / lose tracking if I used the phone.
Another update. No help from “support,” so I’m debugging on my own. Tonight I ended the app on my phone (not running in foreground or background), started exercise / walk on the Sense, walked a mile, had my wife text me, read it, replied. GPS and exercise still running. Opened a weather app, checked the weather, closed the weather app. Got home, ended the exercise / walk on the Sense, opened the Fitbit app on the phone, synced it. GPS and exercise tracking stayed on and recorded the entire exercise / walk session and track. Not a good solution, but a solution just the same. Sense remains non-sense.
09:41
07:24
06-30-2021
09:41
07:24
Hi @Casual-User. Welcome on board. @lifeisgoodnow Thanks for stopping by to help our new member.
@Casual-User Thanks for sharing these details. I understand where you're coming from about getting your GPS activity interrupted and I'm sorry for this inconvenience. Because you mentioned this happens when using your phone, do you recall if you opened the Fitbit app at that time? May I know since when this started to happen? Also, what is the model and OS/software version of your phone?
In the meantime, please force quit the Fitbit app, reboot your phone, restart your watch to refresh its performance, open the Fitbit app, pull down on the screen to force a manual sync and try tracking your GPS exercise one more time.
The issue was noted in a topic on 22 June, so it's been around for a minimum of a month without a fix. It neatly explains my own observation that outside of opening the Fitbit app on my iPhone, any rest stop seemed to crash the Sense (on rest stops I'm probably checking texts, email, taking photos, etc). I'll try your solution - thumbs up for doing the legwork!
Best AnswerI’m the same. Today during my excercise I had a notification from Fitbit suggesting I open the app to allow for regular syncing or some such. I duly complied and it crashed the watch and uploaded half the activity to strava.
I only found out when I got a notification from strava, which was some time after that had happened.
this fault makes it impossible to use the Sense to track activity and then try to beat your best times etc. better off to use my old Apple Watch series 2.
very disappointed and will contact support directly to ask for a return / refund.
Just a note, I have an Android and it does same thing.
Jennifer
Best AnswerHi @Casual_User thanks for your great fault finding , I too had this issue and you are correct in saying that exiting the fitbit app completely, before starting walking exercise on your sense and not reacting to any fitbit notifications and not opening the fitbit app works perfectly.
I logged a call yesterday and today was told the usual restart everything at first which did not work, then was told to follow the thread on the 22nd June which gives info by others too this did not work either, none of those solutions worked.
I found your thread which is 100% correct.
Thanks again for your time sorting out how we can work around this.
Support when I logged a call have told me they are looking into this and a fix will be forth coming I asked when but there was no further info given other than "in due course"
Best AnswerI have noticed on my Sense that if I open the app while using the exercise mode on the tracker that the tracker shuts off the tracking and I get a Fitbit logo that it is rebooting. I just got the Sense two weeks ago after dropping my aging Versa and cracking the screen. I'm on an iPhone running 14.6 Fitbit Sense version 128.5.38 Fitbit v 3.43.1
I'm trying rebooting the phone and tracker.
Best AnswerI have the same problem/. My exercise app on the Sense shuts off when I am doing a walk. My Versa never did that. Can you fix this or do I need my Versa back?
