12-23-2020 14:50
12-23-2020 14:50
How is it my sense will automatically track my ride accurately, yet if you start a workout and use gps it misses a lot of distance?
Best Answer12-23-2020 21:11
12-24-2020 02:37
12-24-2020 02:37
Similar problem here. I've been doing the same 5k run several times a week for 2 years.
Up until 2 weeks ago I used a Garmin & never had a problem but in the 6 runs since I switched to a Sense only 2 have been properly tracked, todays was the worst, nothing tracked on the map for the first 4k.
The total distance is about right but I'm not sure if that's via GPS or a guesstimate based on stride length.
So far I'm less than impressed with Sense's GPS performance.
Best Answer12-28-2020 07:57
12-28-2020 07:57
I had this today first time using sense on my run & it missed part of the run
cant manually change on app either
Best Answer12-28-2020 13:47
12-28-2020 13:47
@Ronnie1234 you won't be able to change it manually. My first experience using GPS was it took a while to connect to satellites. I'm assuming because of location change. The subsequent connects were quick. I would test it again and see if it's ok.
12-28-2020 23:53
12-28-2020 23:53
Great thank you 😊 I’ll see what happens on next run
guess it’s trial & error with new products
